recommended values for pdf_t and pdf_c of masonry when use DmamageTC3D material to model masonry
Posted: Sun Nov 05, 2023 7:30 am
by xgx
Dear STKO team, are there some recommended values for pdf_t and pdf_c for macroscopic modeling of masonry structures?
Re: recommended values for pdf_t and pdf_c of masonry when use DmamageTC3D material to model masonry
Posted: Mon Nov 06, 2023 11:01 am
try to keep those values similar to each other. values from 0.3 to 0.6 (for both tension and compression) should be fine
Posted: Mon Nov 06, 2023 11:29 am
by xgx
STKO Team wrote: ↑Mon Nov 06, 2023 11:01 am
Thank you very much, if I try to model a masonry structure in the micro model method, are there recommended values of pdf_t and pdf_c for brick and mortar?
Posted: Mon Nov 06, 2023 11:43 am
If you use the micro modelling approach, I would typically go with higher values in mortar (around 0.6) and lower (0.1 - 0.2) in bricks.
But it always depends on your specific case
Posted: Mon Nov 06, 2023 11:47 am
by xgx
STKO Team wrote: ↑Mon Nov 06, 2023 11:43 am
Thank you very much. Your suggestion has been very helpful to me.
Posted: Wed Nov 08, 2023 3:32 pm
