different dimensions
MBR
Post by MBR » Thu Oct 19, 2023 11:59 am
Hello
i just started with STKO , it is an amazing tool .
i was working to reproduce the model in webinaire 6 SSi 06-04-2020 but in 2 D model
here is my model
could you please help me ?
thank you
slopembr2.zip
(223.88 KiB) Downloaded 174 times
Re: different dimensions
Post by STKO Team » Mon Oct 23, 2023 8:19 am
There are some mistakes.
Try to correct them by yourself, as in this way you will learn better:
  • In OpenSees, 2D models MUST be in the XY plane. You can rotate your model so that it is in the XY plane
  • Remove construction lines (otherwise they will generate floating nodes in OpenSees). Also those lines have assigned the quad element property (thus the error you are seeing: quad = 4 nodes, edge = 2 nodes)
  • Make sure the free field geometries have the same mesh seed.
Note:
This webinar was quite old.
Now in OpenSees we implemented a new automatic absorbing boundary element which makes the modeling much easier:
check webinar #025 New Element Presentation - ASDAbsorbingBoundary
