analyse
Re: analyse
check this. Same error:
viewtopic.php?f=32&t=2700&p=7900&hilit=Tetra#p7900
Re: analyse
First of all, thank you very much for your answer. I have made some modifications, but there seem to be some problems during the operation. I just came into contact with this software and I don't know how to solve it. Can you help me see where the error is? Thank you very much!
- model.rar
- (30.93 KiB) Downloaded 168 times
- [_I$]10E~Y%[]DBFMMD%X2H.png (71.21 KiB) Viewed 2637 times
Re: analyse
You attached only an image... not the file.
However, from the error: it says that your matrix is singular. You should make sure your model is properly constrained
Re: analyse
I'm so sorry I compressed the image by mistake, this is my modified model, or the same issue, I hope you can see what went wrong, thank you very much
- model.rar
- (343.3 KiB) Downloaded 175 times
Re: analyse
I've identified some inconsistencies in your model:
[1] The lateral ties lack assigned element properties (dispBeamColumn).
[2] Please choose the edges (excluding vertices) to assign interaction, physical, and element properties to line objects.
I've included the updated and functional model in the attachment. Feel free to reach out if you require additional assistance.
- model_rev.zip
- (531.76 KiB) Downloaded 173 times
