Error: can't find "option" attribute
xgx
Post by xgx » Wed Oct 04, 2023 3:37 pm
Dear STKO team, can you tell me how to deal with the problem as following.
STKO ERROR.png (95.07 KiB) Viewed 3303 times
Re: Error: can't find "option" attribute
Post by STKO Team » Thu Oct 05, 2023 7:55 am
It seems you are using directly a Section physicalPropery with a disp(or force)Beam Column element.
You should instead use a BeamSectionProperty (as a physical property), where you specify both the section and integration scheme
xgx
Post by xgx » Thu Oct 05, 2023 12:41 pm
Thank you very much, your advice is useful. But now there is a new problem as following. can you give me some advice?
STKO ERROR can't find key.png (67.71 KiB) Viewed 3272 times
Post by STKO Team » Mon Oct 09, 2023 9:41 am
You did not select a proper selection set in the monitor. Double check it
