The lines are not visible
Posted: Thu Sep 28, 2023 6:19 am
As shown in the image, the line exists, but why can't it be displayed? I can't see them, which makes it difficult for me to operate.
Re: The lines are not visible
Posted: Fri Sep 29, 2023 7:11 am
by ValentinaSB
Hi
[email protected],
There is a button called "show edges", try it. If it didn't help you, please share your .scd file, and I will check why you can't display the edges.
- Screenshot 2023-09-29 090900.jpg (13.37 KiB) Viewed 3130 times
Valentina
Posted: Fri Sep 29, 2023 7:24 am
I tried and it didn't work. At the same time, other computers can display normally.
Posted: Tue Oct 03, 2023 8:02 am
If you have graphic issues on your PC it is probably related to your GPU.
Make sure it meets the minimum requirements for OpenGL (at least it should support 100% of OpenGL 2.1, with not bugs)
Posted: Wed Oct 04, 2023 1:48 am
My GPU meets the requirements and it was fine last month.
Posted: Wed Oct 04, 2023 7:55 am
If it was working fine last month, it means that something happened to your GPU drivers. Try to install the latest drivers
