What does this error mean
Posted: Sun Sep 24, 2023 5:46 pm
Dear STKO team, I built a simple prefabricated frame with STKO, but there was an error when running it that I did not encounter, can you tell me how to solve it?
I really need your help and it will determine whether I will be criticized for my next group meeting. Thank you!
Re: What does this error mean
Posted: Mon Sep 25, 2023 9:44 am
There are some mistakes:
- Rigid Links are connected to floating nodes, and not to the beams. I merged them.
- floatnode.png (6.86 KiB) Viewed 1970 times
- The rigid link should be of type Beam, not bar
- Before the eigen, use a dummy analysis (0 stesp, no wipeAnalysis) to use the penalty method. You have overlapping rigidLinks and equalDOFs on same nodes
- Do the same update on the dynamic analysis
Here's a modified file
- 9-25.zip
- (241.6 KiB) Downloaded 156 times
Posted: Mon Sep 25, 2023 10:05 am
Thanks for the reply, this is so important to me, thank you!
I wonder how you do it with multiple points using the same interaction, is there a quick way to do this? I wanted to develop this structure into a multi-layered and multi-span framework, but there were so many interactions that it took me a lot of time, and it was difficult for me to spot omissions in the process.
Posted: Wed Sep 27, 2023 8:55 am
You can simply create an interaction, select all masters, right click, select all slaves.
Just remember the rule: every slave will be attached to the nearest master
