Pushover curve error
sribeiro
Post by sribeiro » Wed Sep 20, 2023 8:25 am
I want to do a pushover analysis in this model in annex, but when I run it, the analysis is not smooth and also some errors appear on the exe. window (also in annex).
Do you know what can be wrong?
Many thanks!
S
stko error pushover.PNG (886.81 KiB) Viewed 3646 times
PSJ_pushover2.rar
(131.13 KiB) Downloaded 448 times
Re: Pushover curve error
Post by STKO Team » Wed Sep 20, 2023 12:37 pm
Use a penalty in the pushover analysis as you did in the gravity.
You have equalDOFs and RigidLink overlapping on some nodes and this cannot be handled by the transformation method (constraint handler)
sribeiro
Post by sribeiro » Wed Sep 27, 2023 8:44 pm
Thank you for the advice, it actual worked for the nodal load on xx.
However, when I try to apply a transversal load (on yy) I can't get a curve at all. I would also like to try a distributed load to represent better the acceleration from the seismic action, but doesn't work either.
I've been looking through all your youtube videos and couldn't fine why it might be happening.
Do you have any suggestion of what could I do to fix the analysis?
po_v3.rar
(16.51 MiB) Downloaded 435 times
Post by STKO Team » Mon Oct 09, 2023 8:51 am
it's because you're still monitoring the X direction
