Adding simple soil springs
Posted: Fri Sep 08, 2023 5:21 am
by kolozvari
I would like to add soil springs around the basement walls and beneath the building (see screenshot below). Can you please walk me through the procedure on how to do this?
Thank you,
Re: Adding simple soil springs
Posted: Mon Sep 11, 2023 2:06 pm
  • Duplicate the faces of the basement walls. On these duplicates do not assign any element/physical property. In this way STKO will generate only nodes. Fix all dofs of these new faces.
  • Create a node-to-node interaction between the walls and the duplicates.
  • Assign a distributed zeroLength with appropriate materials in X-Y-Z translational DOFs
Posted: Mon Sep 11, 2023 2:42 pm
by kolozvari
That's what I thought, but wanted to make sure. A few follow up questions:
1) Should the duplicated faces be at the same location (overlapping) with the basement walls, or shoul there be any distance in between? If there should be a distance, what should it be?
2) Which one would be a master vs/ slave geometry?
3) In the case of uniform excitation, wouldnt this apply acceleration at the constrained sides as well? Is this OK?
4) What would be the stiffness of the soil springs? Does STKO under "distributed option" assigns the stiffness based on the tributary area? What would be the units of the soil springs?
Please let me know. Thank you,
Posted: Tue Sep 12, 2023 10:47 am
You can do whatever you want. A zero-length does not consider the distance between the nodes. But if you keep a finite distance there will be (only at the beginning) annoying warnings from OpenSees reminding you that you put a non-zero distance while it will not be considered by the zero-length (it's a spring after all).
I typically keep a distance for easy modeling of interaction. Then I move them back to avoid warnings. If you have many (tens of thousands) springs those warnings can slow down the processing of the file at the beginning
Not important, as long as the local axes of interest point from the master to the slave (it is important for non-symmetric behaviors). If the behavior is symmetric it doesn't play a role.
Yes, but it is ok. The fixed nodes are fictitious, you are modeling the effect of the (non-rigid) soil within the springs
You define a stress-strain law in the uniaxial material that you put in the zero-length (so the E will be force/area).
Then, with the distributed option, STKO will take the tributary area (because now your master and slave nodes belong to surfaces) and use it as a stress/tangent multiplier in a parallel material used behind the scenes.
Here is an example:
test.zip
(22.28 KiB) Downloaded 639 times
Posted: Tue Sep 12, 2023 2:26 pm
by kolozvari
all makes sense. Thank you.
Posted: Thu Sep 14, 2023 12:06 pm
Posted: Sun Feb 04, 2024 10:02 am
by Ekreft
Hi, I was just wondering if anyone could explain to me the mechanics behind the simple springs used in zeroLengthContactASDimplex. I am assuming there are two springs in parallel in the normal and in the tangential directions. Is this correct?
Are the springs fully elastics or are there any sliders involved in this contact?
Posted: Mon Feb 05, 2024 6:23 am
Hi, zeroLengthContactASDImplex is a contact element. It does not create two springs. The element allows nonlinearity (sliding) according to the input parameters. For more details and understanding, please refer to the links below.
Webinar that explains the working of contact element:
Documentation of the element on GitHUB:
https://opensees.github.io/OpenSeesDocu ... mplex.html
Posted: Mon Feb 05, 2024 3:29 pm
by Ekreft
Thank you for your reply, would someone be able to point me in the direction of the literature for STKO's formulation of the zeroLengthContactASDimplex element?
Posted: Tue Feb 13, 2024 12:25 pm
Check this and the reference at the bottom of the page
