Infill wall material is not running (error using beamwithhinges)
Posted: Thu Jun 08, 2023 12:34 am
I hope you are doing great.
I'm using the infill material that you showed in your previous webinars. Despite I followed the steps, the terminal showed me the following message:
"element beamWithHinges 17 10 3 7 [expr 5656.85424949238*0.1] 19 [expr 5656.85424949238*0.05] 300.0 1386.4017265312752 167375.06803104692 0.001 [exp..."
I also run the model provided in your website, and actually it has the same error. Please, could you giveme guidance on this topic?
I also attached a simple model (one frame) using gravity analysis. I only use this for testing.
All the best,
Salvador
All the best,
Salvador
