big computational cost
Posted: Wed May 10, 2023 10:31 am
Hello everyone!
I modelled an infill masonry wall in 3d because I want to study the out-of-plane behavior. In particular, I used 2d elements in xz plane. I set a pushover analysis with displacement control to understand the in-plane behavior before. However, the computational cost in term of time is very big! In particular, in the best of cases after 1 hour of analysis the process is still at 50% because it needs many iterations for each increment.
Are there any options in the analysis setting that allow to reduce the iterations? Or other solutions to make the analysis faster?
I attach the model file to show you my setting.
Thank you very much!
Giovanni
Giovanni
