Rubber material
Posted: Tue Jan 03, 2023 6:00 am
which physical property is given for modelling a rubber material as cushion material in piled raft foundation.
Re: Rubber material
Posted: Tue Jan 03, 2023 8:56 am
Rubber in general should be modelled with an Hyper-Elastic material if you want to analyze it under very large deformation.
But this is not the case.
I think cushion is used in composite pile-raft foundation just to redistribute the stress of the piles. So you can just use an Elastic Isotropic material
Re: Rubber material
Posted: Wed Jan 04, 2023 5:08 am
Thankyou so much for the reply. One more query about the element property. Which element property is suitable for rubber material as cushion. I provide SSPbrick element is it ok.
Re: Rubber material
Posted: Wed Jan 04, 2023 11:06 am
Any solid element is fine
Re: Rubber material
Posted: Thu Jan 05, 2023 4:41 am
Re: Rubber material
Posted: Thu Jan 05, 2023 9:20 am
