Moment Curvature using zeroLengthSection
Posted: Mon Sep 12, 2022 7:55 pm
Dear STKO
I want to reproduce in STKO an example of moment-curvature from the opensees wiki page, but performing it on my own fiber cross section.
[https://opensees.berkeley.edu/wiki/inde ... re_Example]
I saw this example replicated using opensees navigator on youtube
https://www.youtube.com/watch?v=M14Mr8GpVRU.
An additional change I'm making to my model is that I'm not putting a concrete cover in, and I'm introducing a min/max model for steel to get a plot like the one below: I tried two ways:
(a) I inserted 2 nodes in the same place 1 [0,0,0] and 2 [0,0,0], then I connected them with the zerolenghtsection command, but that didn't work very well
b) I built a geometry with 2 nodes 1 [0,0,0] and 2 [1,0,0] unit length as in the video :
#07 Learning Opensees: Nonlinear Modeling of RC Frames (Lumped Plasticity)
I do not know why the zeroLengthSection element is created twice in my model (we can see it in the output elements), and why in example #07 the moment-curvature is obtained from the moment-rotation results.
I thought that I should export the M-Kz result and not M-Rz
In addition, the beamsectionProperty and displacement beam column are created in example #07.
My second uncertainty is the value of the target displacement (dk) in the integrator setting of the displacement cotrol.
In the opensees wiki example, this value is calculated. In my example, I calculated
1) epsy = fy/E = 0.0025
2) Ky = epsy/0.7d = 0.0025/0.7*0.36 (h-cover)=0.00992
3) dk=ky/numInc = 0.00992/100 = 0.0000992
Is this correct? The program performs the calculation but if I do the M-KZ plot (with gauss plot) the moment I have only 1 kNm. What should I do to recreate the example from opensees wiki in STKO?
I want to perform the calculation:
a) the bending moment itself (considering that the section is a beam)
b) the effect of the axial force (considering that the section is a column)
I would like to know exactly at what force the bar will rupture or crush the concrete The same way it was done in opensees navigator. I am posting my file from STKO [rar file].
I will appreciate your help.
