Problem in result visualization
Posted: Thu Oct 21, 2021 3:29 pm
by AntoMarinelli
Dear STKO,
when I run this model, the post processor does not allow me to see the results properly.
I attached the file.
Thanks in advance.
Best regards
Antonella
Re: Problem in result visualization
Posted: Thu Oct 21, 2021 5:00 pm
by marafini.f
Hi Antonella,
what problem are you encountering specifically? I could run and open the results properly. I remind you that if you are running in parallel, try not to open the mpco database before the analysis is completed, or at least stop the analysis before loading it.
Let me know specifically what is the problem.F
Posted: Thu Oct 21, 2021 9:36 pm
by AntoMarinelli
The beam appears as in the photo. It is very strange.
Posted: Fri Oct 22, 2021 8:21 am
by marafini.f
You have very high displacements, so the deformed shape of the beam is distorted. Did you check at different time steps? and the load you are applying or the duration of your analysis?
Posted: Fri Oct 22, 2021 9:58 am
by AntoMarinelli
I tried to change but it doesn't work because the beam is not plotted in frist steps. Is your visualization the same?
Posted: Fri Oct 22, 2021 10:18 am
by marafini.f
this is what I see when I run your model as it is
I found some mistakes in your model. You had applied the pin condition to both supports, and also did not apply the equalDOF to the left side interaction infact as you can see from the picture it was breaking on one side.
Here is the corrected file
H1500_FRC75.zip
(736.48 KiB) Downloaded 204 times
Posted: Fri Oct 22, 2021 12:01 pm
by AntoMarinelli
Thank you a lot.
Antonella =)
Posted: Fri Oct 22, 2021 2:10 pm
by marafini.f
you are welcome!
