Page 1 of 2
element zeroLengthSection
Posted: Wed Sep 15, 2021 8:26 am
by Alex Yang
I established a precast assembled double column pier frame structure for quasi-static analysis, but the results show that R is negative in ReinforcingSteel::SetMP()
after: 6 iterations current Norm: 1.61995e-008 (max: 1e-008, Norm deltaR: 7.97907)
NewtnRaphson::solveCurrentStep() -the ConvergenceTest object failed in test()
StaticAnalysis::analyze() - the Algorithm failed at iteration: 0 with domain at load factor -468147
pushover analysis has been done。
I have tried many approaches, but useless.anyone can help me? I will share my command if you give an e-mail address.
here is my e-mail:[email protected]
thanks!
Re: element zeroLengthSection
Posted: Wed Sep 15, 2021 8:51 am
Reinforcing Steel material has many bugs... I would suggest: start with a simpler steel material, check if everything works, then move to Reinforcing Steel
Posted: Wed Sep 15, 2021 9:08 am
by Alex Yang
Thank you for your answer! I replaced reinforcing steel with steel 02, but the results showed that
WARNING - ForceBeamColumn3d::update - failed to get compatible element forces & deformations for element: 14(dW: << 2.31313e-005, dW0: 0.0344486)
WARNING - ForceBeamColumn3d::update - failed to get compatible element forces & deformations for element: 14(dW: << -5.2057e-005, dW0: 12.1848)
Domain::update - domain failed in update
DisplacementControl::update - model failed to update for new dU
WARNING NewtonRaphson::solveCurrentStep() -the Integrator failed in update()
StaticAnalysis::analyze() - the Algorithm failed at iteration: 0 with domain at load factor 1.75654e+006
I think it is the problems of element zeroLengthSection and post-tendon. but i cant asure it.
Posted: Wed Sep 15, 2021 10:43 am
This is a typical non-convergence error with issues related to the force beam column element.
If you share your model (zip it and attach it here) it will be easier to find the issue
Posted: Wed Sep 15, 2021 10:56 am
by Alex Yang
Thank you! I will share my model.
Posted: Thu Sep 16, 2021 8:09 am
by marafini.f
Dear Alex,
which version of OpenSees are you using?
I tried to run your model with mine (3.3.0) but you need to input GJ in the fiber sections. Could you specify this value?
Thanks
Posted: Thu Sep 16, 2021 8:40 am
by Alex Yang
Thank you! my opensees version is 2.5.0, and I tried version 3.3.0 yesterday. it works successfully, but the results obviously wrong. And you can input -GJ 4. which 4 means material tag has been defined above.
Posted: Fri Sep 17, 2021 7:28 am
by Alex Yang
I built my model again which can be run in opensees 3.3.0. but still has a non-convergence error.I will attach my model in this post. can you help? thanks.
Posted: Fri Sep 17, 2021 11:22 am
by marafini.f
Dear Alex,
Nonconvergence problems are typical of any nonlinear analysis. You can try different things, like changing the algorithm. NewtonLineSearch of ModifiedNewton with initial stiffness.
Your result is telling you that the NormX is low but the NormR seems to be very high. You should try to interpret that, why is your convergence failing in terms of forces equilibrium rather than displacement compatibility.
You can try also by testing your cyclic analysis in this way:
integrator DisplacementControl 2008 2 0.0003
set ok [analyze 100]
if {$ok != 0} { error "non-convergence!" }
or refining your analysis by incrementing up to 0.00003 with 1000 duration.
If you had used STKO for your modelling you could have used the Adaptive Time Step option, it would have for sure helped you with your problem.
Enjoy your modeling
Francesca :geek:
Posted: Wed Oct 06, 2021 5:59 am
by Alex Yang
Thank you!
