BeamContact3Dp
Posted: Mon May 24, 2021 2:57 pm
by amalu
I have tried to model the soil pile interaction based on the latest webinar , while running the analysis, the opensees is showing this message
"BeamContact3Dp::setResponse(const char **argv, int argc, OPS_Stream &eleInfo): localAxes unknown request"
This line is followed by the similar lines with 'section unknown request'
'Localforce unknown request' and
'material unknown request' as well.
The same messages displays for "BeamEndContact3Dp" as well.
I have run the webinar example files downloaded from stko website. But those are also showing the same messages.
After referring some previous threads in this forum, I have updated my STKO to latest version (2.0.3) as well as downloaded and installed the opensees compilation (OpenSees-Solvers-1.0.1-Installer) from the link provided in the STKO website.
However iam getting results after analysis. But the messages seems to be important. What should be done to solve this issue?
Re: BeamContact3Dp
Posted: Mon May 24, 2021 3:41 pm
Those messages are not important.
It is just a useless warning from the Beam-Contact elements saying that they cannot provide those results.
Don't care about them.
Re: BeamContact3Dp
Posted: Mon May 24, 2021 3:47 pm
by amalu
Thankyou for the quick response
Re: BeamContact3Dp
Posted: Tue May 25, 2021 5:30 pm
You are welcome!
Re: BeamContact3Dp
Posted: Fri Oct 29, 2021 3:32 am
by BuuNguyen
Can you share the link of webinar and download the example you mentioned?
Thank you in advance.
Re: BeamContact3Dp
Posted: Fri Oct 29, 2021 1:03 pm
by marafini.f
Dear BuuNguyen,
you can find the webinar link and the support files here.
https://asdeasoft.net/?webinar#08
Enjoy :)
