Can't create mpco file
Posted: Fri Apr 09, 2021 4:41 pm
I'm learning how to use STKO to build and run a model with Opensees. Now I encountered two problems with the post-processor.
I think I did the right installation of the software and the pre-processor works. When I download an example file from "https://asdeasoft.net/?stko-example-files" and learn how to build the model, the model is able to run, but I cannot see any output. There is a *.mpco.cdata file but no *.mpco files. There is no error message appearing on the terminal window as shown below. The model is right because I download it from the official website, and the Opensees does not have any problem because it can run other models manually. The version of Opensees is 3.2.2.
I found some ways that may be useful to solve my problem in this forum. Two reasons were mentioned: 1. the version of Opensees is incorrect; 2. the hdf5.dll, szip.dll, and zlib.dll are needed for Opensees. I download an old Opensees from asdeasoft, and copy three dll files to the same directory as Opensees, but neither of them can work on my computer.
Another problem is that when I click "Run Analysis", the Opensees CMD windows will be closed automatically no matter what version of the software I used.
Thanks.
Thanks.
