Regarding modelling of steel channel section
Posted: Fri Apr 09, 2021 7:48 am
by MitalChovatiya73
Respected STKO Team,
I want to model steel channel section but I am not able to find option where i can give any arbitrary section by either manually drawing or giving parameter inputs.
Thank you in advance.
Re: Regarding modelling of steel channel section
Posted: Fri Apr 09, 2021 3:19 pm
by marafini.f
Dear MitalChovatiya73,
To create custom shaped section you can use the Fiber command in: Physical Properties > Fiber > Fiber section.
You can either draw it by hand in the Beam Fiber Section editor, or you can import a geometry that you created in the render view and merge, or even choose among one of the available shapes for the elastic sections.
- Immagine 2021-04-09 170806.png (54.76 KiB) Viewed 2208 times
Let us know if this works for you
Enjoy your modeling
Posted: Sat Apr 10, 2021 5:59 am
by MitalChovatiya73
Dear Francesca,
I got it now how to model arbitrary shape. Thank you so much for your prompt help. Really appreciate it.
Kind Regards.
Meet
Posted: Tue Apr 13, 2021 7:36 am
by marafini.f
I am glad I could help, let us know if you need anything else.
