Procedure for removing or adding elements
Posted: Thu Jan 21, 2021 7:47 am
Dear Team,
What is the right procedure to remove or add elements from the model In STKO? Because every time I remove some elements from my model, it shows an error as given below. but if I make the same model from the beginning with an element removed, then there is no occur.
It is a little difficult to make the same model again and again in order to make some changes.
Zeeshan Bhat
Zeeshan Bhat
