I'd like to use STKO postprocessor for my model, but I keep getting the following error message: "MPCORecorder error: unknown arg with option none" when I use de mpco recorder command.
My model consists of an all-quad unestructured mesh of quadUP elements and I can get it to run successfully without the mpco recorder. Also I've been able to run a couple of STKO examples with the mpco recorder.
I'm attaching a part of my model if it's of any help
MPCO recorder error
PabloEspinoza
MPCO recorder error
- Model.zip
- (1.01 MiB) Downloaded 217 times
Re: MPCO recorder error
It's because in the mpco recorder command, after the backslash, you put some extra space characters. Note that in TCL, when you use the backslash to write a command on multiple lines, you SHOULD NEVER put any extra character after the backslash.
One more note: for element results you need "material.stress" instead of "stress", because you are using a quadUP element that has full integration (4 gauss points). "stress" works with reduced-integration (1 gauss point) elements such as SSPQuadUP
Here is the modified recorder file
PabloEspinoza
It works now!
Thank you very much
Thank you very much
