Fiber section vs Elastic Section
ankurjain1992
Post by ankurjain1992 » Thu Nov 12, 2020 3:12 pm
Sir, I prepared a model in STKO....I found the answers using both Elastic section and Fiber Section. All properties were kept same. They why am I getting variation in Modal Time Periods.
With Elastic Section, I got T1 = 1.299 seconds whereas with Fiber section I am getting T1 = 1.2444 seconds.
Also, I have verified the value T1 using Elastic section in SAP2000. The value matches exactly.
Is this any mistake in my model or it is common thing with fiber section ?
Thank you in advance.
Re: Fiber section vs Elastic Section
Post by STKO Team » Fri Nov 13, 2020 12:07 pm
If in the fiber section you use an elastic material (equal to E/G used in the elastic section) the responses should be equal, but only in theory. In practice, the fiber section is used to obtain an approximate solution , in fact the section is not continuous, but made of a finite number of fibers.
So, for example, the area will be equal, but the second moment of inertia will not!
Just to do a test, try to increase the number of fibers, the finer the mesh, the closer the results
