Lysmer boundary
Posted: Thu Nov 05, 2020 5:14 am
I have reviewed the tutorial for SSI, and tried to implement the Lysmer boundary in my model (as attached).
However, It cannot work every time when I tried to update the material to the plastic stage.
Can we use the same method that showed in the tutorial to 20-8BrickUP element with nonlinear material? or will it is because I use gravity loading (transient analysis) to simulate the correct stress state rather than using body force?
Will it possible for you to take a look at my file? I will appreciate any suggestions.
Many thanks,
Many thanks,
