Hi;
Does "monitor" functionality of STKO not support OpenSeesMP? I tried it with MP but it gives an error and I couldn't be sure it is supported or not.
Also it seems that "download files" link of the 14th webinar (interactions) directs us to the 13th webinar (common errors). Didn't want to open a new topic for this.
Thanks.
OpenSeesMP and Monitor Function
Vefa OKUMUS
MSc. Structural Engineer
PhD candidate.
Software Developer.
Istanbul - Turkey
PhD candidate.
Software Developer.
Istanbul - Turkey
Re: OpenSeesMP and Monitor Function
Hi Vefa,
The monitor function should work for OpenSeesMP as well. Could you show the error that you have?
https://asdeasoft.net/file/webinarFiles ... ctions.zip
Could you double-check it?
This is the link on our website and it seems to point to the right files:Also it seems that "download files" link of the 14th webinar (interactions) directs us to the 13th webinar (common errors). Didn't want to open a new topic for this.
Hi;
Thanks for the reply. I attached an image of the error I get. Single processor works well.
This is strange that I checked that multiple times yesterday. Sorry for bothering you.This is the link on our website and it seems to point to the right files:
- 2020-10-20 08_46_04-Select C__Windows_system32_cmd.exe.png (21.07 KiB) Viewed 3013 times
Vefa OKUMUS
PhD candidate.
Software Developer.
Istanbul - Turkey
PhD candidate.
Software Developer.
Istanbul - Turkey
Oh ok... This is a very rare problem that happened to a just 2 other users. On some windows 10 PCs, when running OpenSeesMP (due to some admin restrictions) it does not read an environment variable that tells the Monitor that we can use Python inside STKO. So it tries to use the Python on your system. But your Python does not have the PySide2 package that instead is available if you run it via STKO's Python.
Once the analysis started, you can simply run the monitor manually, open a terminal windows in the directory where you have your SCD file. There you also have the STKOMonitor Directory. type
.\STKOMonitor\STKOMonitor.batRe: OpenSeesMP and Monitor Function
I am not surprised because MP related rare problems find me every time
Thank you very much for the quick reply.
Regards.
Regards.
Vefa OKUMUS
PhD candidate.
Software Developer.
Istanbul - Turkey
PhD candidate.
Software Developer.
Istanbul - Turkey
