1. imported geometry from an iges file I created using Autocad.
2. I used "planar" to create the surfaces
3. I created elasticMembranePlateSection and assigned it to all the shells
4. I created MITC4 shell and assigned it to all elements.
5. I did the rest: conditions, steps etc.
6. I used structured, Quad, Linear mesh (although I tested also other combinations).
Boundary conditions seem to be adequate, and the analysis runs with no error, but I don't see the deformed shape when I open the database. I see that the values of deflections are enormous (to the order E10). So I think there is a problem with the model. Do I need to "sew faces" in this case? I sewed them, but the problem persists.
Here is what the model looks like:
Note that there is a shell element in every four nodes. Any help would be appreciated! THanks!
