Question about Modal analysis and Modal Participating Mass Ratios
Posted: Mon Sep 28, 2020 2:36 pm
Dear STKO Team:
I build the two story frame in ETABS and STKO, because I want to compare the results of modal analysis in different program.
After I check the result, the result of the third mode (torsional mode)in ETABS is different from the one in STKO.
Then, I try to put the rotational mass in STKO, but the result is still weird. (The distance from mass center to node mass is about 1.5m, so the rotational mass =(1.5^2+1.5^2)^0.5 * (node mass).) Do I put the wrong value in STKO?
How could I solve the problem? I think the result in ETABS is correct, and there maybe something wrong in my model in STKO. Because I check cumulative modal participation masses in STKO, the MX MY and MRZ don't reach 100%. The following is my model and the results in ETABS and STKO.
Any advices and helps that you provide are highly appreciated.
Best Regards
Best Regards
