Force Response History of Elastic Sections
Posted: Sun May 10, 2020 2:06 pm
by vokumus
Hi;
Is there any way to extract time-force history data from elastic elements? There are only nodes, Gauss points and fiber options in extract data menu.
update: solved this adding a custom recorder command. If there is a more convenient way please share.
Thanks.
Re: Force Response History of Elastic Sections
Posted: Mon May 11, 2020 1:57 pm
time history chart refers to a point of the structure. In STKO it's possible to extract it from nodes, Gauss points and fiber.
Unfortunately results on element-nodes (such as force in elastic beam) are not supported in ExractChartData. We will add it soon. In the meanwhile you can do it, using a general dispBeamElement (so with gauss points) where each section is an Elastic section. In this case you can extract section.force at the gauss points near the beam ends
Posted: Mon May 11, 2020 3:24 pm
by vokumus
That's a great way to solve it. It was hard to work with custom recorder. Thanks.
Posted: Wed Dec 04, 2024 4:42 pm
by StavrosP
on a similar topic, using STKO v4.0.0, I would like to extract the local (shear) force of a beam element. I am using "Force-Based beam-column" elements, with Standard Integration Types (Lobatto, 5GPs), with Elastic section. While I can visualise the local shear, I cannot extract the data in a tabular form via the postprocessor. Can you please let me know if there is workaround?
Stavros
- STKO - local shear force.jpg (135.4 KiB) Viewed 2569 times
Posted: Mon Dec 09, 2024 9:58 am
Check this option to make the force-beam-column shear-deformable:
- sheardef.png (31.44 KiB) Viewed 2514 times
Record section.force, and on gauss points you will be able to see and extract the transverse shear.
Note: When the beam is shear-deformable (Timoshenko), shear deformation and force are available at the section level.
When it's not shear-deformable ( Bernoully ), you will only see the shear forces at the element level (force or localForce) due to equilibrium
