Page 3 of 6
Re: Pushover analysis error
Posted: Wed Jul 28, 2021 8:48 am
by marafini.f
See this other post
viewtopic.php?f=54&t=2008&p=3956#p3956
Please do not create numerous threads with the same topic.
Posted: Wed Aug 04, 2021 3:03 pm
by felicegiordano95
Hello i can't see the tensions in the plates.
Posted: Thu Aug 05, 2021 4:21 pm
by marafini.f
Dear felice,
Sorry we didn't get back to you about the stress in the plates.
You should try and use the layeredShell instead of the PlateFiber. You should define the material and then a LayeredShell physical property with at least three layers with specific thicknesses referencing that same material. The sum of the thickness is the total thickness of your slab.
Try it out and let me know how it goes.
Posted: Tue Aug 17, 2021 6:30 pm
by felicegiordano95
I think I succeeded, in the attachment I insert the final file.
Posted: Mon Aug 23, 2021 2:23 pm
by marafini.f
Dear felice,
I did not get what you want me to check.
I just ran the model and the period is very high, maybe you go the unit of the mass or the stiffness wrong?
Please analysis your results
Francesca :geek:
Posted: Tue Sep 07, 2021 10:07 am
by felicegiordano95
Hello I wanted to ask you if the STKO software automatically calculates the g1, that is the weight of the elements, or should I also add this in the vertical loads.
Then I would like to ask if to increase the stiffness of the deck I have to insert a rigid diaphragm as a kinematic constraint, and where I could see a video that explains me how to do it ..
Thanks for your help.
Felice Giordano
Posted: Tue Sep 07, 2021 1:09 pm
by marafini.f
Dear Felice,
the software does not calculate self-weight by itself. You need to input it as a load.
As for rigidDiaphragms it is discussed in many videos, this for example.
https://www.youtube.com/watch?v=vPB9ZwTZbNw
Posted: Wed Sep 08, 2021 10:37 am
by felicegiordano95
Even the mass does not calculate itself? and if so where should I insert it?
Posted: Wed Sep 08, 2021 11:06 am
by marafini.f
No it does not calculate itself. In conditions, you can add mass in the same way you add loads, at the nodes on the edges or distributed on faces.
If you type the word "mass" in the search bar of the forum you will find many threads on this topic that could be of use.
Posted: Wed Sep 08, 2021 4:09 pm
by felicegiordano95
I can't reduce the period of this structure which should be around 1 and instead I get 10.
