Page 2 of 2
Re: ASD CONCRETE 3D TRansient Analysis Mesh sensitivity
Posted: Mon Aug 26, 2024 7:46 pm
by Sylwester
Thank you very much.
I have checked this solution and it also provides a result independent of the mesh density.
But why does the stiffness of E have to be so much higher if we are treating this part of the plate as elastic?
Why 100x more and not 10x or 1000x?
Posted: Tue Aug 27, 2024 7:51 am
Tips:
Ask this to the new ChatBot we implemented in the forum:
I have a slab modeled as a shell. Its Young's modulus is E. I want to make a portion of that slab rigid. What alternatives to rigidLink do I have?
Here's the rationale behind it:
- I want to make a portion of a deformable slab (with Young's modulus E) rigid
- I should use kinematic constraints (rigidLink in this case) to enforce correctly the constraint
- Alternatively I can impose the constraint approximately using a penalty approach
- In the penalty approach I "penalize" the deformability of the stiff part using a stiffer material Estiff = alpha*E
- In theory, to obtain the correct result alpha should be INFINITY, but you can't due to numerical issues.
- Assume you are fine with a 1% error, you can make alpha = 100
- Likewise, if you want an error of 10%, alpha = 10
Posted: Wed Jan 15, 2025 8:05 pm
by Sylwester
Dear STKO,
I wanted to return to the topic of the sensitivity of the result to the density of the MES mesh.
In my attached model, I have done all the instructions in this topic, regarding elastic shear and the connection of the slab to the column also as elastic.
- Displacement.png (37.84 KiB) Viewed 2475 times
I performed the anlysis depending on the density of the mesh. And the smaller the mesh, my deflections differed. Now I don't know which result can be good? I noticed in the results that the value of stresses in the steel (over the columns) does not vary depending on the mesh. The same is the case with the damage
d- of the compression concrete. The big difference I noticed is that the smaller the mesh, the damage
d+ has a different range. But should it affect the result that much?
- MES 04x04.jpg (149.19 KiB) Viewed 2475 times
- MES 02x02.jpg (134.04 KiB) Viewed 2475 times
- MES 01x01.jpg (124.34 KiB) Viewed 2475 times
- MES 0,3x0,3.jpg (153.98 KiB) Viewed 2475 times
Can you please advise how to choose a mesh in this type of situation ?
Best regards
Posted: Fri Jan 31, 2025 10:52 am
Actually, this happens because the initial mesh is very coarse for this kind of problem.
The solution converges as you approach a mesh of 10 cm.
- slab.png (21.94 KiB) Viewed 2348 times
