Sorry I can't understand, which is the previous post you're talking about?
With the Standard Integration method I can consider plastic hinges with finite length at the ends of beam and column elements?
Thanks in advance
No, you should use hinge option in this case.With the Standard Integration method I can consider plastic hinges with finite length at the ends of beam and column elements?
