Page 2 of 2
Re: Nothing to regenerate
Posted: Fri Nov 25, 2022 3:22 am
by amb_1
Dear STKO Team
This is one of a group of non free field trials. Due to the impact of the COVID-19 epidemic, I can't provide many information now. Later, if you need it, I will provide it
Best wishes
Posted: Fri Nov 25, 2022 8:30 am
Is there some "interface" material between the box and the soil?
Posted: Sat Dec 03, 2022 2:43 am
by amb_1
sorry. I just got back to you now. I've solved this problem. Thank you for your suggestions
Best wishes
Posted: Wed Dec 14, 2022 5:10 pm
Posted: Fri Jun 23, 2023 6:52 pm
by sebi_magi
Was the issue with the PDMY03 model partition solved? I am using this model in STKO. My model converges using 1 to 4 processors, but using more than that causes the model to crash at different stages.
Kind regards.
Posted: Tue Jun 27, 2023 8:37 am
It has been fixed here:
https://github.com/OpenSees/OpenSees/pull/1054
So the new OpenSees version should have this issue fixed
Posted: Tue Nov 26, 2024 1:47 pm
by BuuNguyen
1, about InitialStateAnalysisWrapper, in the dynamic analysis of gravity balance simulation, some cases using (InitialStateAnalysis on/off), in some cases there is no use InitialStateAnalysis on/off), In opensees website (https://opensees.berkeley.edu/wiki/inde ... s_of_Slope) and OPenSesPL website (https://www.baidu.com/link?url=7Z2pPZDR ... 03637cedb9), however, according to the comparison of my simulation results, I found that sometimes the two results are similar, and sometimes they are quite different. Could you please tell me whether they are used in dynamic analysis?
As stated in the documentation, using the InitialStateAnalysisWrapper can create unwanted oscillations in transient analyses. It can be solved using a dummy slow analysis without any laod after the OFF command. But if you don't need to put a frame or shell structure on the soil domain, you don't really need the initial state wrapper at all.
[/quote]
Hi STKO, what does the dummy slow analysis mean in this case?
I run dynamic analysis with user-defined modulus reduction curve (or yield surfaces) of PDMY material, but got the error:
"FATAL:PressureDependMultiYield::updateActiveSurface(): error in surface motion.
A= 4.66066e-20 B= 3.52034e-10 C= 2.72227e-13 (t1&&t1)= 2.65902"
However, it ran well if I remove the OFF command of IniitialStateAnalysis. you can check it in attached file
Thank you,
Buu,
Posted: Thu Nov 28, 2024 9:39 am
It's a convergence error within the material. If you can avoid the initial state wrapper, don't use it
