Page 2 of 6
Re: Pushover analysis error
Posted: Fri Jul 09, 2021 5:15 pm
It looks like you assigned a load to a node that belongs to a geometry without any element assigment. If a geometry does not have an Element Property, it will not be translated to an OpenSees element.
Posted: Mon Jul 12, 2021 3:19 pm
by felicegiordano95
How should I assign the horizontal load?
As, as previously said, I am developing the analysis by considering the deformability of the diaphragm.
Posted: Tue Jul 13, 2021 8:58 am
Are you referring to "How to assign horizontal loads for a pushover if you don't have a rigidDiaphragm"?
It really depends on your structure, and it is not a numerical issue.. it is more a theoretical one
Posted: Tue Jul 13, 2021 6:06 pm
by felicegiordano95
I entered the horizontal load in the following way, but nevertheless it generates an error during the analysis.
Therefore, I am sending you the inherent file.
Posted: Wed Jul 14, 2021 4:57 pm
I've just seen your model,
it is singular because your second geometry (travetti) is detached from the other.
One more question, you are using the SurfaceLoad utility on a shell which is physically modelled... If you model the slab then you need to use the FaceForce, while the SurfaceLoad is applied on a geometric surface when you don't want to model the slab.
What approach do you want to use?
Posted: Thu Jul 15, 2021 8:45 am
by felicegiordano95
Should i merge the geometry? Also because I can't do it ..
I don't know what kind of approach to use, which one do you suggest? I had thought of applying the seismic forces directly in the lateral nodes of the structure .. tell me which one could be the best.
Posted: Thu Jul 15, 2021 8:49 am
by felicegiordano95
And anyway, if I start the analysis, the analysis error I sent earlier always appears in the image.
Posted: Thu Jul 15, 2021 9:02 am
by felicegiordano95
I am attaching the updated file
Posted: Fri Jul 16, 2021 9:50 am
Dear user,
here is your model which is working fine now
Esempio 3.1.scd.zip
(1.9 MiB) Downloaded 190 times
There were still few errors that we fixed:
  • travetti and main-structure geometries should be merged
  • I had to add a few more construction lines in the merge operations to guarantee a quad mesh
  • Master node geometries should be removed, because you don't have rigidDiaphragms, so those nodes will be unconstrained
  • I added a other constructions lines in the slabs such that their interactions generate a vertex at the center of each floor, where the master nodes were. Just to use it as a monitor for top displacement.
  • beams had a hinge-integration scheme, but now that they are merged with the slab, and therefore meshed, that integration rule is not applicable anymore, so I converted them into distributed (Lobatto) rule with 3 points each one.
Also note that you are doing a pushover in X, but your nodal loads are applied to a face parallel to the X axis, so your model is rotating.. I don't know if this was what you wanted.
Posted: Fri Jul 23, 2021 10:11 am
by felicegiordano95
Hello, I wanted to ask you how I can visualize the voltages inside the plate elements and how to extract the results.
Also I wanted to ask you if it would be better to lower the joists (travetti) and make them coincide with the upper edge of the plate.
