I would like to use the face mass condition to assign a value of load depending on the z-coordinate. I want the load to be -392.4 when the z-coordinate is equal to -100 and take a value according to the following equation when z>-100:
-9.81*0.707*(-60-z). I have tried the following but I am not sure if it works properly:
-392.4*(z==-100) -9.81*0.707*(-60-z)*(z>-100)
Any help will be appreciated.
Thank you!
Konstantinos
FACE MASS FUNCTION MODE
konstantinosch
Last edited by konstantinosch on Fri Dec 20, 2024 11:56 am, edited 1 time in total.
Re: FACE MASS FUNCTION MODE
First, for a load you have to use the FaceForce, not the FaceMass.
That being said, you should provide a graph of the function you want, otherwise we cannot tell you if that function is fine or not
konstantinosch
Sorry for my oversight. I wanted to apply a face load. The equation that I want to have is:
The graphic representation is shown in the attachment.
- Load vs depth.png (50.1 KiB) Viewed 2359 times
In this case this is not fine:
This means:
-392.4 If Z is exactly -100, -9.81*0.707*(-60-z) if Z > -100, 0 otherwise
You can do this:
-392.4*(z==-100) -9.81*0.707*(-60-z)*(z>-100)-392.4 If Z is exactly -100, -9.81*0.707*(-60-z) if Z > -100, 0 otherwise
You can do this:
-392.4*(z<-100) -9.81*0.707*(-60-z)*(z>-100)
