Installation errors
Yara
Installation errors
Post by Yara » Tue Oct 15, 2019 1:12 pm
Hi there,
When trying to install the software I get the error depicted in the attached figure. Could you advise how to overcome this?
Ricardo
Re: Installation errors
Post by Ricardo » Tue Oct 15, 2019 3:31 pm
Hi Yara
This kind of error can happen if
1) you are re-installing STKO while the previous installed version is running (is this the first time you install STKO?)
2) or if you don't have administrator rights on your PC (do you have administrator rights on the PC?)
if these are not the cases, try to download STKO again, probably the downloaded file got corrupted (or, like in my case, make sure you don't have an anti-virus that blocked the execution of the downloaded STKO installer)
Let me know if you fix this error ;)
Yara
Post by Yara » Wed Oct 16, 2019 2:45 pm
Many thanks Ricardo!
I ran it as admin and it works now. :)
AsadZia
Post by AsadZia » Sat Dec 07, 2019 6:59 am
I am trying to add a screenshot and picture but it does not work.
Problem is that
I opened and run the STKO. But when I open it again it is unable to open and gives the error message as given below:
1.1.Exception during activation
"Activation limit exceeded for this key".
Asad005
Post by Asad005 » Sat Dec 07, 2019 7:57 am
The screenshot of the window showing the error is added in attachments.
Problem is that
admin
Site Admin
Post by admin » Sat Dec 07, 2019 8:37 am
Hi Asad,
Now try again! The problem should be solved.
Thank you :)
Asad005
Post by Asad005 » Sat Dec 07, 2019 9:58 am
Yes, it is working now. :) :)
More than thanks.
122Y
Post by 122Y » Thu Feb 27, 2020 3:41 pm
Hi, I tried to open the software but it is unable to and gave the error message:
Post by STKO Team » Thu Feb 27, 2020 5:06 pm
Please click on System Info button that appears in the window that shows the error. And post the code that you see
122Y
Post by 122Y » Tue Mar 03, 2020 12:12 am
The code is: 2B4A75E8D8EEBE00092A4260751EDF6096604494480A39B0
Locked
