How to show the stress in fiber section
BuuNguyen
Contact:
Post by BuuNguyen » Tue Oct 29, 2024 6:39 am
Hi STKO,
I want to get the color stress map of the fiber section (tunnel) as in the attached file. However, the colored dot is so small, I can not see the color map of the whole tunnel.
Can you please suggest any solution for this?
Thank and best regards,
Buu
color map.JPG (33.14 KiB) Viewed 2913 times
Re: How to show the stress in fiber section
Post by kesavapraba » Tue Oct 29, 2024 7:47 am
Hi, Please use particle size factor, in your case: increase it.
BuuNguyen
Contact:
Post by BuuNguyen » Wed Oct 30, 2024 8:42 am
Yeah, Thank you, 1 one question.
When I used ZerolengthASDImplex for soil-tunnel interaction. I already define Cylindical local axis and apply it to the contact element (with +Y axis point from tunnel to surrounding soil). But when I show the local axis of the contact element. It seems that the local axis was not applied correctly. as you can see in the figure. Can you check my model?
Thank for your support.
model.rar
(842.85 KiB) Downloaded 105 times
Post by STKO Team » Wed Oct 30, 2024 9:42 am
Cylindrical and Spherical local axes use the local Z as their outward normal vector. They are meant to be used in 3D models where the contact requires the local Z, not in 2D where the contact direction is the local Y.
There is a workaround:
In the attached model I:
  • Scaled (2D) the structure with respect to its center of a small amount (scale factor = 0.99). This creates a small gap between master and slave
  • In contact element I changed the orientation to "From Link Direction" (usable when the distance is > 0). Then I also switched on the "Rigid Gap" option, to tell OpenSees that this initial gap is not a real gap, but just a geometrical offset
model.zip
(1.32 MiB) Downloaded 146 times
BuuNguyen
Contact:
Post by BuuNguyen » Wed Oct 30, 2024 12:10 pm
Yeah, I see, Thank you very much for your support,
Buu
Post by STKO Team » Thu Nov 07, 2024 12:01 pm
