Analysis did not converge
jpereirasan
Post by jpereirasan » Thu Jun 06, 2024 8:35 pm
Dear STKO Team.
I am modeling a centrifugal test, basically it is a sandbox to which a dynamic analysis is performed. To simplify the modeling, it can be worked as a slope and apply the constraints correctly.
I have the problem that the model does not converge and i can not advance to the post process part, i think it has to do with an error in the analyze command, how can i fix it so that the model gives me at least a preliminary result?
I would be very grateful for your help.
dynamictest.rar
(97.38 KiB) Downloaded 124 times
Re: Analysis did not converge
Post by kesavapraba » Fri Jun 07, 2024 4:54 am
Hi, It seems you are dealing with 2D analysis since you have applied the boundary conditions in 2D. So, redo (or rotate the model) everything on X-Y plane instead of the current X-Z. Because, all the 2D modeling should be done in X-Y plane in STKO.
jpereirasan
Post by jpereirasan » Tue Jun 11, 2024 7:07 pm
Problem solved, thank you!
Post by STKO Team » Wed Jun 12, 2024 7:19 am
