Dear STKO team.
I am modeling a centrifugal test. After performing the static and dynamic analysis of the model and going to the post process I get results in the nodes but not in the elements.
What is the cause of this and how can I fix it?
Not getting results in the elements
jpereirasan
- Screenshot_5.png (67.57 KiB) Viewed 819 times
- Screenshot_6.png (19.89 KiB) Viewed 819 times
- CentrifugeElements.zip
- (22 Bytes) Downloaded 100 times
Re: Not getting results in the elements
Your zip is empty.
Anyway I think you are using reduced-integration elements. If this is the case, in the recorder choose strain and stress instead of material.strain and material.stress (you can do it in the custom element results)
