problem with the tutorial
joselito15
Post by joselito15 » Fri May 31, 2024 4:46 am
I have a problem with the second model of the tutorial "STKO E-Learning Course - Modeling a Reinforced Concrete Frame Structure (english webinar)", it gives me an error regarding the value of the concrete "Error: the fracture energy (Gf = 3) is too small or the characteristic length of the element (lch = 153.333) is too large.
The minimum Gf to avoid constitutive recoil is 0.0283"
Imagen de WhatsApp 2024-05-28 a las 19.57.04_49651b09.jpg (252.1 KiB) Viewed 1276 times
Re: problem with the tutorial
Post by STKO Team » Mon Jun 03, 2024 7:44 am
The error is clear:
You are using a mesh that is too large for the fracture energy in compression (Gc = 3).
In the original example it was a 100 mm mesh size, you are using instead 153
joselito15
Post by joselito15 » Mon Jun 03, 2024 4:14 pm
Where can you change the mesh size?
Post by STKO Team » Tue Jun 04, 2024 7:30 am
In the Mesh tab. using either the global mesh seed, or the edge seed. Please see the user manual
