Boolean operations
Lei Lei
Boolean operations
Post by Lei Lei » Mon Feb 26, 2024 2:18 am
Dear STKO,
Can I use Boolean operations on volumes and surfaces in STKO?
For example, use a face to cut an object into two parts, or a line to cut a face into two parts.
Thanks for your reply!
Re: Boolean operations
Post by STKO Team » Mon Feb 26, 2024 9:26 am
Sure, use the Merge command
Lei Lei
Post by Lei Lei » Tue Feb 27, 2024 1:41 am
If I use 'Merge', only the separate ones are turned multiple into one.
I want to find a method to cut a 3D geometry into two parts by a plane.
I tried 'Subtract', which only saves the parts of the two geometers that do not overlap. It isn't what I want.
Post by STKO Team » Tue Feb 27, 2024 9:10 am
The "Merge" is the foundation of every boolean operation.
In your case you can:
  • Merge
  • Explode
Lei Lei
Post by Lei Lei » Tue Feb 27, 2024 12:10 pm
Thanks!
It does make sense!
By the way, after merging and exploding, is there any way to combine multiple geometers into one without retaining contact surfaces?
And, I found that after merging, it is impossible to copy, move, and so on the substructure. It seems that the components still belong to 'merge' without independence.
Post by STKO Team » Thu Feb 29, 2024 9:56 am
It's not clear to me.
Can you share your model and a sketch to explain what you are trying to obtain?
Lei Lei
Post by Lei Lei » Fri Mar 01, 2024 9:03 am
Certainly!
I've imported a 3D segment model and utilized a plane to execute a cut using operations like 'Merge' and 'Explode', similar to what's depicted in Figure 1.
Figure 1
Now, my objective is to modify the right segment independently. However, despite the explosion, each part remains grouped within the 'Merge' operation, hindering individual manipulation as seen in Figure 2.
figure 2
Post by STKO Team » Wed Mar 06, 2024 9:06 am
Repeat the explode command on that geometry. The explode command may be used multiple times in nested loops
Lei Lei
Post by Lei Lei » Wed Mar 06, 2024 11:32 am
I still have this question.
For example, I hope to union the A and B without a public surface.
However, whether I use 'union' or 'merge', there is still a public surface.
Is there any way to solve it?
Thanks!
Post by kesavapraba » Wed Mar 06, 2024 3:21 pm
Hi, You can handle the individual geometry after the explode command executed multiple times. So, the extra surfaces can be deleted.
Just a suggestion for the first issue that you pointed out, why don't you make two copies (say 1 and 2) of the solid+plane geometry in the same workspace and do the merge for both and then use subselection for geometry to delete the right part after the plane for 1 copy and delete the left part before the plane for 2 copy. Doing so, you will have two separate geometries, you can bring them together at a common vertex.
