a strange problem when trying to perform a three-dimensional microscopic modeling of masonry structure.
xgx
Post by xgx » Sat Oct 28, 2023 11:41 am
Dear STKO team, I encountered a strange problem when trying to perform a three-dimensional microscopic modeling of masonry structure. However, when I conducted a gravity analysis on one wall alone, the analysis proceeded normally and there were no issues. However, when I merged several walls to create a masonry house, I encountered the error in the following image. I really don't understand why. The boundary conditions are set as shown in the figure below, and I don't think there is any problem. This question has been bothering me for several days, and I would greatly appreciate it if you could answer it for me.
Re: a strange problem when trying to perform a three-dimensional microscopic modeling of masonry structure.
Post by STKO Team » Mon Oct 30, 2023 9:13 am
If you see the line "Warning: numeric analysis returns -1" it means that your model is singular.
From what I can see from the image, your slab is not attached to the walls
xgx
Post by xgx » Mon Oct 30, 2023 10:02 am
Dear STKO team:
Thanks for your reply, but it seems that you misunderstood what I want to express. In fact, I have merged the slab and wall, but I accidentally set the shader color of the slab to red, which caused you to misunderstand. Even if I removed the slab, only four walls remained, merged them, fixed the bottom, and ran the analysis, the program still reported this error. This really troubles me. I have attached my SCD file. Could you please help me check it.
cyclic test of masonry structure3_r6.zip
(10.59 MiB) Downloaded 241 times
xgx
Post by xgx » Mon Oct 30, 2023 10:22 am
Dear STKO team:
At present, what I can confirm is that all the walls have been merged into a masonry structure. I fixed the bottom of this structure and conducted gravity analysis, but still encountered the error of singularity in the stiffness matrix. Because of this, I really don't understand why. I sincerely desire for your reply.
Post by STKO Team » Mon Nov 06, 2023 11:58 am
It runs in my case.
Probably your model is too large (too many DOFs) for a single processor.
Try using parallel analysis with OpenSeesMP
xgx
Post by xgx » Mon Nov 06, 2023 12:29 pm
It runs in my case.
Thank you for your advice, however, I tried to do as you said, but it doesn't work.
xgx
Post by xgx » Mon Nov 06, 2023 12:31 pm
It runs in my case.
So, the reason for this issue is actually due to insufficient performance of my computer?
xgx
Post by xgx » Mon Nov 06, 2023 12:48 pm
It runs in my case.
Thank you very much, your suggestion inspired me. After increasing the grid and reducing the number of grids, it can run normally.
