'NoneType' object has no attribute 'XObject'
Dear STKO team, can you give me some advice to deal with the problem as the following picture
- error1.png (74.03 KiB) Viewed 4106 times
Re: 'NoneType' object has no attribute 'XObject'
I need the full error (in your image I cannot see the last lines).
But I'm pretty sure you did not assign a physical property to some geometries
Thank you for your reply, and the information you need is in following picture
- 物理属性指派错误.png (89.07 KiB) Viewed 4051 times
Exactly, as you can see from the last line, one of your beam elements (either disp or foce based) are missing a physical property
