The lines are not visible
[email protected]
As shown in the image, the line exists, but why can't it be displayed? I can't see them, which makes it difficult for me to operate.
- 6AS2Z%TWL{M7GQ[ZL{(S)U4.png (19.02 KiB) Viewed 3155 times
- ~THH[5JL8XBHWO_)F6_V%CC.png (17.75 KiB) Viewed 3155 times
ValentinaSB
Re: The lines are not visible
Hi [email protected],
There is a button called "show edges", try it. If it didn't help you, please share your .scd file, and I will check why you can't display the edges. Best,
Valentina
Valentina
[email protected]
I tried and it didn't work. At the same time, other computers can display normally.
- C2K2YB.rar
- (323.37 KiB) Downloaded 265 times
If you have graphic issues on your PC it is probably related to your GPU.
Make sure it meets the minimum requirements for OpenGL (at least it should support 100% of OpenGL 2.1, with not bugs)
[email protected]
My GPU meets the requirements and it was fine last month.
If it was working fine last month, it means that something happened to your GPU drivers. Try to install the latest drivers
