ASDConcrete3D material model - Material test not working
AntoRoma
Post by AntoRoma » Fri Feb 17, 2023 11:40 am
Hi team,
I’d like to test the ASDConcrete3D material model for a numerical calibration of a cyclic test we performed at the University of Minho. However, the material test tool does not work and reports me an error message (see attached).
Could you please help me to fix it?
We have just updated STKO to the latest version v.3.2.1.
Thank you for the support.
Re: ASDConcrete3D material model - Material test not working
Post by STKO Team » Fri Feb 17, 2023 1:04 pm
That is only the last part of the error message. Could you please scroll up until you see the the OpenSees output? Could you copy-paste that here?
AntoRoma
Post by AntoRoma » Mon Feb 20, 2023 10:41 am
Hi, is this fine? Thank you for the support
Post by STKO Team » Mon Feb 20, 2023 11:09 am
It's because you are using an old OpenSees version without the ASDConcrete3D.
Please make sure you are using the lates STKO release and the latest OpenSees-Solvers (download the unofficial version from prof. Tarque's website as the current official version of OpenSees still has to be recompiled with this material)
AntoRoma
Post by AntoRoma » Mon Feb 20, 2023 2:02 pm
Now, it's fixed. Thank you very much for the support.
Post by STKO Team » Mon Feb 20, 2023 2:44 pm
a1rodrig
Post by a1rodrig » Wed Jan 03, 2024 1:01 am
Dear STKO,
I have encountered the same problem. However I am using OpenSeesMP version 3.4.0
Is there another repository where prof. Tarque's version can be found? Currently the link to the Drive folder says that the file does not exist anymore.
Thank you for your help.
Andres R
Post by kesavapraba » Wed Jan 03, 2024 6:45 pm
Hi, It is being fixed. You can check the same link tomorrow since there was an issue with the server.
a1rodrig
Post by a1rodrig » Fri Jan 05, 2024 6:56 pm
Hi, Thank you for the prompt reply.
I wanted to ask if the link has been updated? I checked the link once again of Fri Jan 05 and still could not find the files. I attached the links I am using and the screenshot of the corresponding website.
-- Links --
https://asdea.eu/software/system-requirements/
https://drive.google.com/file/d/1WHdo96 ... share_link
Post by kesavapraba » Mon Jan 08, 2024 6:13 am
Hi, we checked with the Professor, the link is yet to be updated. We will resolve this issue as quickly as possible and update you here. Sorry for the incovenience caused.
