Model construction with Python API
Re: Model construction with Python API
Thank you so much!
So now how can i create a quad mesh with pythonAPI?
Hi team,
i would like to implement, within my python code, the materials pimy and pdmy to model my soil layers. The parameters are the standard ones for medium clay and medium sand that are on openseeswiki. I attach the file below
thanks for your help!!
- MakeGeometry - prova PIMY.rar
- (3.19 KiB) Downloaded 175 times
Just change these 2 lines (use_rho is not an attribute of PIMY, and PIMY is just in ND folder, without the sub-group name)
Add this to the end of your file. By the way, you cannot do a full quad mesh, because of the cuts you have in the deposit shape
mc = doc.meshControls
mesh_size = 10.0
for _, gc in mc.geometryControls.items():
for fc in gc.faceControls:
fc.topology = MpcMeshAlgoTopology.TriaTetra
fc.algorithm = MpcMeshAlgo.Unstructured
for ec in gc.edgeControls:
mesh_seed = MpcMeshEdgeSeed()
mesh_seed.type = MpcMeshEdgeSeedType.UniformBySize
mesh_seed.size = mesh_size
ec.seed = mesh_seed
App.runCommand("BuildMesh")
The material PIMY run well for bedrock but not for soil layers. Why?
The error is as follows.
For what concerne the mesh, I have problem with the package MpcMeshAlgoTopology and MpcMeshAlgo too.
Can you help me?
Thank you!!
Fabiola
Can you help me?
Thank you!!
Fabiola
- MakeGeometry - prova PIMY 3.rar
- (3.31 KiB) Downloaded 173 times
- error pimy.PNG (17.72 KiB) Viewed 3262 times
ValentinaSB
Hi Fabiola,
Regarding the error. Check the indent on lines 178-181. With the correct indent, it works for me. Also, check one more time the indent for your mesh part with for loops. Let me know.
As Valentina said, you have indentation issues.
First in line 178 (as the error message says). Here you mixed tabs and whitespaces as indent (this is not allowed in Python). You have to be consistent in your file, either with whitespaces or tabs for indentations, don't mix them.
Secondly, you completely disregarded indentation in the nested for-loops for the meshing part.
- MakeGeometry - prova PIMY 3.zip
- (3.35 KiB) Downloaded 186 times
Thank you!
Now the focus of my work is to assign the AbsorbingBoundaries on boundary sides (as in the figure) by API python.
Can you tell me how I can write the tag correctly?
Sorry for all the requests.
I await your reply, thank you again.
- Absorbing.PNG (29.51 KiB) Viewed 3175 times
I added a code to select all boundary edges for absorbing boundaries.
Now you can proceed as we did for physical and element properties of the main geometry
- (3.72 KiB) Downloaded 184 times
Hello team!
I'm here again to ask for your help. This time i'm modeling directly on STKO and i don't be able to run the analysis. I don't know where i s the problem, maybe it's about the mesh? I don't know how i to do. I attach the file.
Thank you for your help.
Fabiola
Fabiola
- Schema 1.rar
- (364.98 KiB) Downloaded 220 times
