Dear Sirs,
is there any way to move a vertex of an existing geometry ? This vertex is already connected to other geometric elements.
Thank you very much
Moving a vertex in an existing geometry
Re: Moving a vertex in an existing geometry
Unfortunately, it is not possible. If you share a screen of your model, probably we can give you an alternative solution
Thank you very much for your reply. I solved the issue adapting the geometry.
Thank you !
Thank you !
