Dear STKO Team
Is there any way to save the contour plots in vector format, such as PDF, SVG, eps, etc.? Because such types of plots are required in publishing results. I am aware the option exists in the monitor option, but not in the post-processor display. The snipping tool workaround is not that effective, I am not interested to use that solution, which does not improve the image resolution.
It would be helpful if there is any script that I can use in the script editor of the post-processor of STKO. Thank you.
Script for saving contour plots
Re: Script for saving contour plots
Not now but we are planning to include it
That's fine. Thank you for your reply. You might update me once it is available.
