Extract Data from zeroLength elements
liyanwentj
Post by liyanwentj » Tue Aug 24, 2021 2:41 am
There are several node-to-node zero-length elements in my model. How to extract the element end force-relative displacement data in the post-process?
Best regards.
Re: Extract Data from zeroLength elements
Post by marafini.f » Tue Aug 24, 2021 7:54 am
Dear liyanwentj,
to extract results in the post-processor you create a new chart data from the work tree and select the nodes and or elements and appropriate results just following the data extraction wizard.
For zero-length elements whether they are collapsed in one node or have an actual length, the procedure is the same.
Did you check out our manual
https://asdeasoft.net/pdf/manual_STKO_may_2021.pdf
if you need more assistance please attach your model so we can make an example directly on it.
Enjoy your modelling
Francesca :geek:
