How could I call the toolbar?
luckypants
Post by luckypants » Sun Aug 15, 2021 3:03 pm
Dear STKO Team:
I close all the toolbar to take a screenshot, and I want to call the toolbar now.
But I do the right click and there is not any response.
How do I solve the problem?
Best Regards
Re: How could I call the toolbar?
Post by marafini.f » Mon Aug 23, 2021 8:39 am
Dear luckypants,
you should clear your registry data.
We wrote a quick python script you can run on your pc for you. Just run it from the Windows Console with STKO closed and it will restore the default interface.
resetCaeMainWindow.zip
(404 Bytes) Downloaded 341 times
Let us know how it goes.
Francesca :geek:
luckypants
Post by luckypants » Mon Aug 23, 2021 11:04 am
Dear marafini.f:
I have run the python script from cmd, but it still not work.
How could I solve the problem?
Best Regards
Post by marafini.f » Mon Aug 23, 2021 12:53 pm
Dear luckypants,
I have the same error if I run the script twice.
Could you try again in this order:
- close STKO
- run the script
- reopen STKO
Let me know
Francesca :geek:
luckypants
Post by luckypants » Mon Aug 23, 2021 1:01 pm
Dear marafini.f:
I have done the order you said. It still not work.
There is the same error message.
Best Regards
Post by marafini.f » Mon Aug 23, 2021 2:15 pm
If you see in the script we are trying to clear the registry of your computer from those two files called "State" and "Geometry" in the folder "Software\ASDEA Software Technology\STKO\CaeMainWindow".
Can you go into your registry with administrator access and manually erase the files?
luckypants
Post by luckypants » Mon Aug 23, 2021 3:03 pm
Dear Francesca:
I found that there wasn't the files in CaeMainWindow, and there wasn't also CaeMainWindow there.
Best Regards
Post by marafini.f » Tue Aug 24, 2021 7:57 am
Dear luckypants,
that's not the system registry.
You need to type regedit in your windows search bar, run regedit.exe as administrator and navigate to
"Computer\HKEY_CURRENT_USER\SOFTWARE\ASDEA Software Technology\STKO\CaeMainWindow"
Here you should find the two files I mentioned before:
See if you can reach this folder and erase the files
luckypants
Post by luckypants » Tue Aug 24, 2021 8:55 am
Dear Francesca:
Thank you very much. :D :D :D
It works now.
Best Regards
Post by marafini.f » Tue Aug 24, 2021 10:09 am
You are welcome!
