Dear Team,
I tried to do two different ground motions separately, but I am getting the residual drift from first analysis in my second analysis as shown in Figure attached. Although I have enabled the wipe analysis command also.
Any suggestions will be appreciated.
Zeeshan Bhat
Multiple time histories
Zeeshanbhat
- image.png (23.13 KiB) Viewed 1186 times
Re: Multiple time histories
The wipeAnalysis just resets the settings of the analysis (algorithm, constraint handler, analysis, etc...).
If you want to reset your model status to a "virgin" stage, you need to use the "reset" command.
