Analysis due to matrix singularity
Asad005
Post by Asad005 » Thu Dec 31, 2020 10:19 am
Dear Stko team,
I am receiving an error when I run 3d fem model.
Please help me out with the following error. Waiting for your kind response.
thanks & regards :|
The file is attached herewith.
WARNING MumpsParallelSolver::solve(void)- Error -10 returned in substitution dmumps()
cause: Matrix is Singular Numerically
WARNING ModifiedNewton::solveCurrentStep() -the LinearSysOfEqn failed in solve()
StaticAnalysis::analyze() - the Algorithm failed at iteration: 0 with domain at load factor 0.1
3D, RealF, Solid1.zip
(1.08 MiB) Downloaded 150 times
Re: Analysis due to matrix singularity
Post by STKO Team » Tue Jan 05, 2021 9:49 am
Here is a working copy (I just tested the first vertical analysis):
3D, RealF, Solid.zip
(709.28 KiB) Downloaded 201 times
The problem was in the solid-bar interaction:
The solid should be the master and the bars should be the slaves.
I also increased the penalty parameters of the first analysis to 1.0E16. Do the same in the second analysis (I forgot to do it)
I also increased the peak strain of your concrete model, it was too small. It should be larger than fcp/E.
Asad005
Post by Asad005 » Fri Jan 22, 2021 4:32 pm
Thanks for being so kind.
regards
