Dear STKO Team:
I tried to build the seven-story structure with plastic hinges. However, there was the convergence problem in my model.
I couldn't get the result.
I also built the same model in ETABS to check the result. I found the ground motion caused structural damage and permanent displacement to the structure.
The following is my model. How could I solve the problem?
Any advice and helps that you provide are highly appreciated.
Best Regards
Seven-story structure (convergence problem)
luckypants
- sevenstory nonlinear.rar
- (371.57 KiB) Downloaded 497 times
- ETABS.jpg (79.24 KiB) Viewed 5551 times
