Installation errors
Re: Installation errors
Post by STKO Team » Thu Mar 05, 2020 10:07 am
It looks like you correctly activated your license in our database the 27th of February. For some reason it didn't work on your PC. Try now
122Y
Post by 122Y » Thu Mar 05, 2020 12:46 pm
Yes it's working now, thank you!
[email protected]
Post by [email protected] » Mon Mar 23, 2020 2:20 am
Hi, I have the same problem (appears the same error message ) and tried to install the software again, but did not succeed. Hence, if necessary, the code in the System Info is 2B4AE8D8EDA8BE80B89AE464A438214058A23BC083D067B0.
Thanks in advance
Post by STKO Team » Mon Mar 23, 2020 12:48 pm
Try now
[email protected]
Post by [email protected] » Mon Mar 23, 2020 3:47 pm
Now, everything is right. Thanks a lot
mesay
Post by mesay » Tue Jun 23, 2020 6:50 pm
"networking error(5)"
activation key..
Code:
2C4AF4E4E8A2945823201CF8EB983F70AAA285B03FA439B0
Post by STKO Team » Wed Jun 24, 2020 1:23 pm
Hi Mesay,
Try now! The problem should be solved.
Thank you :)
RiccardoDi%20Blasio
Post by RiccardoDi%20Blasio » Tue Aug 11, 2020 7:07 pm
Ciao, anche io ho questo problema.
Grazie
Locked
